Dashboard does not show select drive option
I am trying to get express cache to work. Support had me load SSD Dashboard. Dashboard says it finds my drive, but the information displayed is for my C drive (standard hard drive) not the SSD.  The tech and the manual says there should be a box in the upper right to select the drive to display. The option is not there.
The SSD is displayed in windows disk manager with a basic volume. The format of the drive is the Express Cache Format and not a windows format.
Anyway, I think the SSD is bad and I am trying to find a way to test it.
Any guidance would be appreciated.
thanks
iosman
@iosman123 wrote:
I am trying to get express cache to work. Support had me load SSD Dashboard. Dashboard says it finds my drive, but the information displayed is for my C drive (standard hard drive) not the SSD.  The tech and the manual says there should be a box in the upper right to select the drive to display. The option is not there. tweakbox tweakbox tweakbox
thanks
iosman
thanks issue has been solved.
