Until Sandisk fixes this, the 2.3.3.0 installer download file has un unuseable extension.
If you “save” it, you have to change the 1560727807 extension to exe before you run it.
If you “run” it from the webpage, the file goes to a TEMP folder somewhere, still with
the useless extension, and does not run/install as-is.
OK to run the executable with an existing installed Dashboard, this installer removes
previous version before updating. Added note: This newest version now allowed
completion of the SMART long test on an SSD with F/W UF4500RL which previously
“hangs” with Code 27 on earlier Dashboard versions.
