Hello there!
I’m trying to create new script to toggle WiFi power on My Passport Wireless Pro device.
The problem is, I’m not really sure where can I listen/create/add on buttons event (I’m talking about SSH access).
Any hints?
Cheers, and happy new year!
I would recommend you to please check the compatibility of my passport wireless.
You can see this KBA-
https://support.wdc.com/knowledgebase/answer.aspx?ID=11737&s=#wireless
Hi there @Logan.S!
I’m not sure if you understand what I’m asking for
I’m willing to make custom script to disable WiFi using button, for that I need to “catch” an action of button pressing from linux OS. And that’s the thing I’m looking for.
Cheers
