Cruzer Titanium 2.0 lights up briefly then goes off. Computers (2 different ones) won’t recognize it. Problem may have been caused by trying to put it into a compuer with a security case installed in a classroom podium. Cruzer had to be inserted at an angle due to configuration of case and how it obstructed access to the USB ports. It’s stopped working, won’t stay lit, and computer doesn’t read it. Same problem reading it with my laptop at home. I need my data - HELP!
if this happens on all computers it is pretty much done. it will need to be replaced. if you bent the connector trying to insert it in the computer with the security box it could have broke the solder points on the USB connector.
