Cruzer Glide Write Protected
I have a 16GB Cruzer Glide USB drive with around 1GB of data on it. I’ve been using it without fail for years, so I know it works with my computer setup (Custom built Windows 7). Plus, I have a second identical drive that also works with no issues.
However, today the drive wouldn’t let me delete or edit files. It was write protected. I quickly made a backup of all my data on the drive.
After Googling, I attempted to repair the read only state using diskpart. After following some of the steps, the drive’s attributes stated:
“Current Read Only State: Yes”
“Read Only: No”
etc…
Now the drive doesn’t show up in WIndows Explorer and no repair utility I try is able to detect the drive at all. Only diskpart and disk management are able to pick it up.
How can I reformat this drive to get it back into a working state? I am willing to lose the data since I already made a backup, however I can’t even seem to find a way to format it.
I think it may be time for a replacement.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
First Method:
Start >> Run >> Diskpart (Hit Enter) You would see black Command Prompt Screen
Type ‘List Disk’ and Hit Enter
Type ‘Select Disk #’ (# is the corresponding number of USB drive obtained in above step
Type ‘Clean’ and Hit Enter
Type ‘create partition primary’ and Hit Enter
Type ‘Active’ and Hit Enter
Type ‘format fs=fat32 quick’ and Hit Enter
Type ‘assign’ and Hit Enter
Second method:
Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer. Connect your Sandisk USB flash drive or pen drive again, and you should find the write protection is removed by this write protection removal software and the device is no longer write protected.
SanDisk Suport indicates that the drive sets itself to “Protected” when it detects a fault situation.
They say there is no work around.
You must send the drive back to them and they will replace it per the warranty, if you use the online form noted in the support area.
https://kb.sandisk.com/app/answers/detail/a_id/8656/kw/usb%20write%20protection
This method does not work when the USB drive write protects itself upon detecting a fault.
Returning under warranty is all SanDisk offers.
aftre hint ‘Clean’
i’ve got this message
“DiskPart has encountered an error: The request could not be performed because of an I/O device error.
See the System Event Log for more information.”
actual situation
DISKPART> attributes disk
Current Read-only State : Yes
Read-only : No
Boot Disk : No
Pagefile Disk : No
Hibernation File Disk : No
Crashdump Disk : No
Clustered Disk : No
Run this command and it will work.
DISKPART> attributes disk clear readonly
Disk attributes cleared successfully.
