cruzer edge with Linux
Hi, my USB flash drive is recognized but I have this message:
Archive:  /media/E856-4210/SanDiskSecureAccessV2_win.exe
[/media/E856-4210/SanDiskSecureAccessV2_win.exe]
  End-of-central-directory signature not found.  Either this file is not
  a zipfile, or it constitutes one disk of a multi-part archive.  In the
  latter case the central directory and zipfile comment will be found on
  the last disk(s) of this archive.
note:  /media/E856-4210/SanDiskSecureAccessV2_win.exe may be a plain executable, not an archive
zipinfo:  cannot find zipfile directory in one of /media/E856-4210/SanDiskSecureAccessV2_win.exe or
          /media/E856-4210/SanDiskSecureAccessV2_win.exe.zip, and cannot find /media/E856-4210/SanDiskSecureAccessV2_win.exe.ZIP, period.
Could someone give me a helping hand please?
What app are you running that gives you that msg?
I’m ust using archives manager.
I use file manager
What’s the flavor on your Linux here and version? Try to do a simple yum update and see if it works.
:flushed:  I didn’t pick up on the OS in the title.  Isn’t SecureAccess a Windows app?  Thus wouldn’t you need to run WINE to run SecureAccess?
