I have messed up a SanDisk Cruzer Edge 16GB
I did not use U3 Launchpad Removal Tool nor u3-tool
I have had the bad idea to use Linux Fdisk
and so I ended up using HPUsbDisk tool to get a properly partitioned and formatted drive
Now LPInstaller.exe does not recognize my U3 device anymore
Windows XP SP3 format nor DiskManagement tool can’t handle it correctly anymore
Is there a way to fix the content of the first track (0-62 512 bytes sector) and get LPInstaller.exe to work? Is there something to erase completely and fix the corrupted u3 flash drive?
Thanks
some information about the device:
u3-tool -i /dev/sg4
u3_partition_info() failed: Failed executing scsi command: Status (S:0x2,H:0x10,D:0x8)
fdisk -l /dev/sdd
Disk /dev/sdd: 16.0 GB, 16008609792 bytes
255 heads, 63 sectors/track, 1946 cylinders, total 31266816 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000e2518
Device Boot Start End Blocks Id System
/dev/sdd1 63 31266815 15633376+ 7 HPFS/NTFS/exFAT
usb 1-1: new high-speed USB device number 4 using ehci_hcd
usb 1-1: New USB device found, idVendor=0781, idProduct=556b
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Cruzer Edge
usb 1-1: Manufacturer: SanDisk
usb 1-1: SerialNumber: 20060878xxxxxxxxxxxx
scsi3 : usb-storage 1-1:1.0
scsi 3:0:0:0: Direct-Access SanDisk Cruzer Edge 1.20 PQ: 0 ANSI: 5
sd 3:0:0:0: Attached scsi generic sg4 type 0
sd 3:0:0:0: [sdd] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
sd 3:0:0:0: [sdd] Write Protect is off
sd 3:0:0:0: [sdd] Mode Sense: 43 00 00 00
sd 3:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
