I just installed a 16gb cruzer flash drive as a quick fix for a bad hard drive, seems to work, however, the following msg appeared,
I’m getting a "Performance Warning” message, what does that mean?
If your device doesn’t meet Xbox 360 performance recommendations, you may experience significant performance problems playing games from the device or saving games and profiles to it. Buy an Xbox 360-branded USB Flash Drive to ensure optimal performance. More info"
It’s a Sandisk drive and sandisk makes the xbox labeled drive, so why would this show up?
