# Create a Playlist on a Sansa Clip
**URL:** <https://forums.sandisk.com/t/create-a-playlist-on-a-sansa-clip/45069>\
**Category:** Sansa Clip  |  Clip+\
**Created:** [February 13, 2009, 3:43pm UTC](https://forums.sandisk.com/t/create-a-playlist-on-a-sansa-clip/45069 "2009-02-13T15:43:09Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![dhott](https://avatars.discourse-cdn.com/v4/letter/d/cdc98d/32.png) [@dhott](https://forums.sandisk.com/u/dhott)\
**Post date:** [February 13, 2009, 3:43pm UTC](https://forums.sandisk.com/t/create-a-playlist-on-a-sansa-clip/45069/1 "2009-02-13T15:43:09Z")
</div>
I have a Sansa Clip. I created a Playlist on Windows Media. When I did a sync over to the cip all the songs show up but there is nothing in the Playlis section. How do I creat a named Playlist on the clip?
**Author:** ![niko\_sama](https://avatars.discourse-cdn.com/v4/letter/n/7bcc69/32.png) [@niko\_sama](https://forums.sandisk.com/u/niko_sama)\
**Post date:** [February 14, 2009, 7:20pm UTC](https://forums.sandisk.com/t/create-a-playlist-on-a-sansa-clip/45069/2 "2009-02-14T19:20:59Z")
</div>
There are several ways to create a playlist for the Sansa Clip.&nbsp;&nbsp; There are many posts on the forum.&nbsp;&nbsp; You may wish to search for other ways.&nbsp; [http://forums.sandisk.com/sansa/search?submitted=true&q=creating+playlist](https://forums.sandisk.com/sansa/search)
There is a way to do it through WMP and there is a good article on the knowlegebase:&nbsp;
[http://kb.sandisk.com/cgi-bin/sandisk\_en.cfg/php/enduser/std\_adp.php?p\_faqid=6&p\_created=1221199598&p\_sid=6-fvntqj&p\_brand=sansa](http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=6&p_created=1221199598&p_sid=6-fvntqj&p_brand=sansa)
Here is one on translating an m3u list:
[http://kb.sandisk.com/cgi-bin/sandisk\_en.cfg/php/enduser/std\_adp.php?p\_faqid=224&p\_created=1223700507&p\_sid=6-fvntqj&p\_brand=sansa](http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=224&p_created=1223700507&p_sid=6-fvntqj&p_brand=sansa)
There is a small utility program for the Sansa e200 series, but I’m thinking it will work for the Clip/Fuze as well.
[http://www.anythingbutipod.com/forum/showthread.php?t=2381](http://www.anythingbutipod.com/forum/showthread.php?t=2381)
[http://www.download.com/Sansa-playlist-creator/3000-2169\_4-10723962.html](http://www.download.com/Sansa-playlist-creator/3000-2169_4-10723962.html)
**But what works easiest for me in MTP mode** , is to open up the Clip in Windows Explorer,&nbsp; open the music directory.&nbsp;&nbsp; select a group of mp3’s&nbsp;&nbsp; then right click them and select create playlist.&nbsp;&nbsp; This may not work in MSC mode.&nbsp;
Good luck,
**Author:** ![bluesun](https://avatars.discourse-cdn.com/v4/letter/b/8797f3/32.png) [@bluesun](https://forums.sandisk.com/u/bluesun)\
**Post date:** [June 14, 2017, 4:39pm UTC](https://forums.sandisk.com/t/create-a-playlist-on-a-sansa-clip/45069/3 "2017-06-14T16:39:15Z")
</div>
I use just audiobooks, each a bunch of ordered chapters in a folder in Internal Memory/Audiobooks. With my many Fuzes over the years, all I had to do was highlight the Create Playlist option on my PC display of Audiobooks, type in the book’s name with a .pla extension, and move it to the Playlists folder.&nbsp; Easy as pie.&nbsp; The same Create Playlist option is on the Clip+ & it creates a playlist file. A couple of times using the .pla extension has actually worked. Usually they disappear or the rest of the books are in a giant playlist named “Unknown.” I’ve tried using the .m3u extension and it also creates a playlist file. But when I click on it, there are no entries. I’ve tried when hooked to a Windows 7 PC in MSC and MTP mode. I’ve even used a share-ware utility designed to create m3u playlists for the Clip (they don’t mention the Clip+). I don’t keep Windows Media Player on my Windows 7 box (I consulted with Microsoft a while ago and was assigned to fixing the bug-ridden WMP 8).&nbsp; Is there an easy way to take a folder of .mp3 (or other supported format) files and create a playlist without having to follow Sandisk’s instructions, which are slightly more complex than building a nuclear bomb?
