Corrupted Disk
How do I reformat a corrupted MD for MAC from circa 2015. It has plenty of room on it for my files.
Hi @Benaclark2 ,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
The formatting of any storage device is basically the same. However, the process of formatting a memory card can vary depending on the device you are using. I would suggest check this article to know how you can format your drive on Mac.
Thanks for responding. I tried erasing/reformatting using the disc utility on my MAC. Got a failure message no matter what I tried. Decided to buy a new external drive.
A Seagate this time.
Ben
