I converted a video clip with SMC and it output the file to the Video folder of the Fuze+ player. So far so good. Now if I copy the file from the Video folder to my PC then delete the file from Fuze+ and then try to copy the file from my pc back to Fuze+ via drag and drop I get the following message:
The Title 1.avi file type is not supported on this device. If it is a media file,
you may be able to use Windows Media Player to…
I read in other posts that if the video file format is correct that files can be “drag n dropped” to Fuze+.
I’m thinking the file must be correct because is was created by SMC and moved to Fuze+ originally.
I downloaded the latest firware version to the player and using the latest verison of SMC.
What could be the reason why I get this message?
