Is it possible to copy songs and audio books (not from audible) back to my computer from a Clip+? The files seem to disappear. I didn’t save one of them and would like to reformat the device and start ovrer.
You should be able to simply drag & drop (copy & paste) them from the Muisc folder (or wherever they’re stored) on your Clip+ to your computer with no problem.
Make sure the Clip is set to MSC That way it will work like any usb flash drive.
Unless the files were originally transferred to the player in MTP mode. If they were, the computer won’t be able to see them while the player is in MSC mode.
