Copy single file from USB - Progressbar?
I want to copy single files, folders from USB to Drive or the other way. Is there a way to get a progress bar to see how the status of copying files is? Maybe over app or admin dashboard?
I use WD my passport Pro Wireless 2TB Version with latest update
Under Activity from the Mobile App you should be able to see a progress bar when transferring files.
The dashboard only allows you to see a progress bar when creating a full USB/MyPassport Wireless backup.
