Hi, i have a 4gb Sansa Fuze V1, in the sansa media converter i cannot convert my video unless the player is plugged into the computer, see
Note :
·If your Sansa Media Player is connected, the converted video will be directly copied across; if the Sansa Media Player is not present, the video will be converted and saved to a temporary path, which you can set by clicking the Menu
button, then selecting Tools and then Option.
Also after adding a video file i’m unable to trim the video unless it has been converted 1st, does anybody have a solution for these 2 problems, i do have the latest media converter. thanks Roger.
