converting pictures to fuze
When I try to convert a picture file to the sansa fuze, the converter doesn’t let me convert the file, it just sits there, and the convert button isn’t lit up
The same thing happened to me…make sure that your Fuze is plugged in and then try it.  After the photo is converted it will automatically sync to the Fuze.  I got this info from Sansa Tech Support and now I have no problems converting photos. I hope this helps.
Photos can also be synced to the Fuze by using WMP. Even tho many people think its sloppy.
