Convert PST to MBOX
If you want to convert PST to MBOX, I would suggest that you use KDETools PST to MBOX Converter. It is the most professional software that easily saves data in various file formats like PST, MSG, EML, EMLX and HTML. The advanced tool converts all types of PST files such as. B. password-protected, orphaned, corrupted, heavily encrypted, corrupted, etc. files. Supports both ANSI and Unicode file types.
There are many types of third party tools which are capable to convert PST file to MBOX file format without any data loss, I recommend a PST repair tool (DataRepairTools) that can fulfill your requirements. It has a unique software functioning in just a few clicks, users can locate and repair the PST files and then convert it into an MBOX file format. The tool Support Windows Operating Systems - 10, 8.1, 8, 7, Vista, XP, 2000 and 98.
Hey if you want to export PST files to MBOX then you can use the fastest and safest Cigati PST Exporter Tool. It can easily import your PST files data to MBOX without any hassle. It also saves your files from being corrupt and damage and from any type of data loss.
