If you want to choose the advanced tool for ost to pst Migration, I would strongly recommend you, try ost to pst converter. With the help of this tool, Outlook users can easily import all the mailboxes of ost to pst with all internal entities like Contacts, task, calendars, appointments, attachment, etc,. ost to pst converter provides the free trial version which helps you can migrate the first 30 items of folder.
more info-
Convert ost to pst
You can try this advance OST to PST converter tool for offline OST to Outlook PST file conversion. It is the most trustworthy tool available on the internet which is recommended by professionals for accurate conversion. It can save your OST file in multiple formats without disturbing the original file structure. This tool also provides you the free trial version, so the user can check its reliability. To get detailed information, check the link below:
https://www.datarepairtools.com/ost-to-pst-converter.html
