Convert GPT to MBR?
Hi there,
Just bought 2 MyPassport for Windows 2 TB drives.
My PS4 will not read the files on them, even though they are formatted to FAT32, I am assuming it’s because the file scheme is GUID and not MBR.
I have a Mac, and Disk Utility will not give me the option of changing the scheme from GUID to MBR.
How can I reformat these drives to FAT32 with a MBR file scheme ???
Help !
Hello, pinky153,
Well, for the live testing and precise information you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
