Convert Blu-ray to iPad 2 for Freely Watching Blu-ray?
Blu-ray to iPad 2 Converter: Convert Blu-ray to iPad 2 for Freely Watching Blu-ray on iPad 2
Apple released the iPad 2 on March 2 and it would be available just days after. Do you want to enjoy your exciting Blu-ray movies with your new iPad 2 on the go? Then you should need a Blu-ray to iPad 2 converter, which could help you convert Blu-ray to iPad 2 friendly file formats there for you can watch Blu-ray on iPad 2 on the go. Blu-ray to iPad 2 Converter is just the one you need, which convert Blu-ray to iPad 2 with video and audio well synchronized and enhances fantastic Blu-ray enjoyment on your iPad 2. The following content are some simple and practical steps to guide you on how to convert Blu-ray to iPad 2 for free watch Blu-ray on iPad 2 with this Blu-ray to iPad 2
The following picture would show the overview procedures for you to convert Blu-ray to iPad 2 friendly file formats:
Convert Blu-ray to iPad 2 step 1: launch the Blu-ray to iPad 2 converter and add blu-ray disc or folders to this Blu-ray to iPad 2 converter by clicking buttons showed above. You can choose the chapters you want to convert, select subtitle, audio and angle, rename Destination File, re-order the converting order, preview Blu-ray movie, snap screenshot, etc.
Convert Blu-ray to iPad 2  step 2: select output profile for your Blu-ray files by clicking " Profile >iPad" to choose the desired iPad 2 file formats. If necessary, you can reset codec parameters for your desired output profile by clicking " Settings".
Convert Blu-ray to iPad 2 step 3: start Blu-ray to iPad 2 conversion by clicking " Convert" button.
Once finished, you can transfer/sync the converted videos to iPad 2 via iTunes.
