I have multiple instances of backups where much of the data is the same. This is the result of having backups of replacement drives from the same laptop (thanks to whoever make Dell HDs). Is there any WD-sanctioned utility that I can use to consolidate duplicate files? Thanks.
Hi there and welcome to the WD community.
There is no software by WD that can consolidate the files, however there are some programs that can help you with this procedure. lets see if another user can help you sharing some tips and information on this matter
