Connecting harddrive to tv wirelessly
Hi, I have a sony bravia TV (kdl-40cx520) and a 4tb WD mybook essentials harddrive (wdbacw0040hbk-h1) with heaps of movies n tv shows on it. is there a easy way to connect these wirelessly cause i want to leave the harddrive on the table and not have to connect it to the tv with usb cable
Hello, with the My Book connected to the PC, you have the option to make it available to the other devices on your network. If your TV is not capable of playing the movies, you can use a WDTV Live Streaming or a WDTV Live Hub to access your content. Check the links below for more information.
How to share a folder in Windows that can be viewed with the WD TV Live, Live Streaming, Live Hub, or Live Plus
http://wdc.com/en/products/homeentertainment/mediaplayers/
