I have a trusty 8GB Sandisk e280 (v1 I believe). It is more or less full. It is set to MSC B mode. I don’t use (or want to use) Microsoft’s Windows Media Player. I want to wipe all the music off it and replace with new material.
I can connect it up to a Windows 2000 PC without problem, showing all directories and files.
I can connect it to a Windows XP SP3 PC without problem but can’t see / access the MUSIC directory.
A Windows XP SP3 Laptop doesn’t even recognise it!
Two questions:
- How do I get it connected to a Windows XP SP3 system and have it show the MUSIC directory?
- Is there any way quickly to wipe the contents of the memory (Initialise / Format / etc.)?
Thanks in advance for ay help.
