Pardon the dopey question, but I’ve been forced to XP by the Fuze (mostly Win2K til now.)
What is the proper procedure for disconnecting the Fuze from the computer? When I just yank the USB out of the Fuze the PC either locks up or the USB wifi quits.
did you upgrade to win xp from 2k? or did you do a fresh HD format and installed win XP? my guess is the upgrade between win2k may be causing the lock up.
also just wondering what your hardware specs are (cpu, ram ,etc).
It was a fresh install of XP. (Totally different box then the other 4 Win2K machines I use.)
‘Safely Remove Hardware’ option is what I’m used to on Win2K. Didn’t see fuse in the list, so I thought it was a function of XP or something not showing media devices?
Nope, just checked. Doesn’t show on the connected devices.
Message Edited by jecottrell on 05-09-2008 10:29 AM
that’s working? msc mode that is? if your only gettting crashes with MTP mode, than something is up with the mtp drivers. but your WMP crashes your comp even with your fuze isn’t connected? that’s most interesting, what are your system hardware specs?
