Is there a way to override the connected mode? I am charging my fuze using my laptop but need to use the radio feature. If anybody has a suggestion I would appreciate it.
Only way I know of to listen and charge at the same time is with a wall charger, I’m afraid:neutral_face:
In a pinch, you can slowly wiggle the USB plug in to the port, about half-way. The power pins are longer than the two center data pins. The Fuze will draw DC power from the bus, but as long as the two center pins haven’t made connection, the Fuze will charge.
Bob :smileyvery-happy:
Yes, with the cable plugged into a wall charger the Fuze will still play the radio & mp3. I’m doing that as I’m typing this. ![]()
