All of a sudden my computer is not connecting with my clip+ The screen shows that its connected and the player is getting a charge How to remedy
Disconnect and try a reset (hold the power switch on for 20-30 seconds). Also, if you haven’t done so, you might try setting the player’s USB mode to MSC–that tends to be the least finicky.
