I made a cloning from SSD (500GB) to SSD Ultra 3D SSD and the PC does not started with the Windows 10. I made the modifications in the BIOS in order to have a boot from de SSD , but the msg in black screen is : there is no system in the HD selected.
I used de EaseUs program and also the Macrium Reflect.
With the first one the cloning is made. With de Macrium , nope. I received a error msg related do “Unable to match partition”.
I bought the disk to have all the programas there but I am feeling the use will be only as a data storage.
Anyone with this kind of problem?
Thanks from Rio de Janeiro
