Everytime I power-on, I set the clock! It does not work. What am I missing? I thought the firmware upgrade would help; It did not.
If you have WMP10 or 11, you could set WMP to automatically set device clock, connect in MTP mode, then format using WMP… Might not work, but it’s worth a shot.
Still No Good… Thank You, Anyway!
I normally just plug mine in, and WMP syncs the clock together, if my time is off most of the time.
The problem as I see it is that the battery that run the clock is flat or is nonexistant… There is probably a hardware error. Hoept his helps ![]()
