So I bought a 4gb Clip+ at Best Buy for $50 I know I paid a high price but I wanted it NOW.
The + is really an advance over the Clip; folder view works perfectly with proper sorting, it’s pretty close to gapless playback, the UI is nicer.
The pitch bug is gone…just for comparison I started the Clip and Clip+ in the same flac song after 1 minute the Clip was 1 second slower than the Clip+.
You can’t base a digital speed test on an analog start. You’d have to use some type of program to actually compare real time speed results on both players. It may seem like you started both players at the same time but even just a fraction of a second off can result in what happened in your situation.
Don’t knock yourself for the price: you paid the standard, list price, which is a good one for the Clip+. (By comparison, the Amazon.com price right now is only $1.75 less.) Good for you, and good to hear that you like it (and that it seems more accurate pitch-wise to you)!
