clip sport won't turn on
I recently bought this mp3 player charged battery installed updates
loaded music worked great turned off won’t turn back on
reset didnt do anything
If the player is at least .20% charged, then try holding down on the Power/Select button for ~25 secs.
The player should turn on. If not, repeat the process. Should work by the 3rd try.
If this keeps happening, probably having a nasty problem.
