Clip Sport Plus
I use a SanDisk Clip Sport Plus for Audible Books.  Everything works fine when I use the Audible Manager.
My problem is, when I try to use the Audible App, no sound comes out of the right earpiece.  I normally use a Bose headset, no sound out of the right ear piece.  When I use the earpiece that came with the device, no sound comes out of the right earpiece.  When I use a wireless head set, no sound comes out of the right earpiece.  Again, this is just when using the Audible App.
I purchased a new SanDisk Clip Sport Plus, just got it today. Same thing, so it is not the device!.
Works fine when I transfer through the old Audible Manager.
I use the Audible App installed on a Windows 10 computer, transferred to the SanDisk.
I spent some time on the phone with Audible support.  The said they have no idea, suggested that I continue to use the Audible Manager.
Anybody got an idea what is going on with the Audible App?
Thanks
Take a look at this related message with a solution on the SanDisk Forum.
http://forums.sandisk.com/t5/SanDisk-Clip-Sport/Clip-Sport-MONO-only-outputs-to-Left-Earbud/td-p/364399/highlight/true/page/2
This worked.
THANK YOU VERY MUCH!!
