My OS is Linux Mint 13 (Maya),OS recognises the MP3 player and names it “clip sport”,I can navigate the folders fine,but when I try to drag and drop I get an error Message: Error creating directory: Read-only file system,Permissions are set where they should be.
The comand I gave only tells you what version of MTP you are running.
I think you may need to upgrade Mint, and the issus is more likely (now that I think about it more) to be with the USB-storage-device handling. T_hat said, I have had no issues with either my two SanDisk Clip Sports (or earlier Sansa Clip Zips) with Ubuntu 13.10 or 14.04 …_
