clip+ show no characters
My Clip+ won’t display any characters anymore only the icons.  I try to reboot but it did not work.  What can I do???
Did you try a reset? You also could reapply the firmware to the player (see the firmware upgrade sticky thread at the top of the forum)–but note that this will erase the content on your player.
I think you mis-spoke there Miikerman ; it’s actually ‘formatting’ that will erase the content, not re-installing the firmware. :wink:
You betcha’ …  my bad.    :frowning:
Ulp.  You betcha’ …  my bad; I stand corrected, correctly.        Sorry–
I tried to reset the “thing” more than once but it failed every time.
Firmware upgrade proved to be the solution … Problem solved:smileyvery-happy:
and it did not erase the content … just reset the settings to factory standards.
Thank you very much Miikerman and Tapeworm
once again your knowledge has been very helpful:wink:
