Clip Power Struggle - Please advise
Clip will work when connected to computer, but will not power up without being connected.  Holding power up to manually reset does not work.  Leaving plugged in to charge for long period of time does not change issue.  Is there a fix to this or is it likely a hardware issue?
Message Edited by clipuser12345 on 02-17-2010 02:07 PM
Message Edited by clipuser12345 on 02-17-2010 02:10 PM
Probably hardware. Older Clips had a battery lead connection problem. If you’re an adventurous soul and handy with a soldering iron, you might be able to fix it.
Otherwise, it’s probably
I agree.  There’s an RMA in process.  Hopefully Sansa will agree as well.  So, no, I do not think I will be doing any soldering…  Thanks.
Well then, if it’s still under warranty that’s a horse of a different color! :smiley:
