I’ve had my Clip Plus less than a month. The first thing I noticed, is that when I used the Clip Plus with a silicone skin on it, the Clip Plus would stop suddenly and need resetting. So, I stopped using the silicone skin. A week or two later, I noticed that periodically, the Clip Plus would be hot to the touch on the front and when it was so, the screen would be blank. If I turned it off for a few minutes, the case would return to a normal temperature and the screen would start working again. I’m thinking I should return it because I am thinking it is defective. Do you agree?
I’m thinking you’re right.
Thanks for confirming my judgement.
