Hey Guys!! I need help, I got a new clip+ and plugged it in my Linux computer (ubuntu 10.4),
my computer doesn’t detect it or automount, the sansa is working properly in my friend’s computer
he has de same operating system(ubuntu)
this is my out put from lsusb:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 046d:c018 Logitech, Inc. Optical Wheel Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 006: ID 0781:74d0 SanDisk Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
As you see, my player is detected under Sandisk corp.
but I don’t see any icon on my desktop or under my computer
or under media.
please need help!!!
Message Edited by GalloPinto on 05-20-2010 11:25 PM
Message Edited by GalloPinto on 05-20-2010 11:26 PM
I have the same issue on Karmic (9.10). lsusb:
Bus 005 Device 002: ID 046d:c018 Logitech, Inc. Optical Wheel Mouse
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 016: ID 0781:74c2 SanDisk Corp.
Bus 001 Device 002: ID 07cc:0501 Carry Computer Eng., Co., Ltd Mass Storage
Anyone have any suggestions?
Use MSC mode on the Clip+ with Linux systems. Not MTP and not Auto Defect.
MSC mode did the trick, the device is found and connected. But, the second partition shows up as not formatted. Is this a known bug? Running Ubuntu 10.4 on AMD64 running 32 bit. Where do I put audio files? Thanks! Ric
That’s probably the external memory card slot. You may be getting this message if you don’t have a memory card in it.
The Music folder I think would be an excellent choice.
