I am using sansa clip with firmware v01.01.18F. Now since last few months I am truble in connecting it to pc. The device is not detected at all by windows7. Have tried all the usb modes,formatting,reseting etc.
It is not being detected by sansa updater also. I guess updating the firmeware may fix the problem. Please guide me how to update the firmware in such condition. and how to make the device discoverable.
P.S.- A freind of mine once tried to charge the player with the mobile charger (with matching mini-USB connecter). can this cause any problem to the port of player? if ya, hoe can i make it sure that the port of the player is damaged?
You may want to go into the Device Manager under Windows 7 and unauthorize the Clip-listed devices (with the Clip disconnected)–then connect up and this will force Windows to try to set up a connection from scratch. This sometimes wil help and fix matters.
To unauthorize, you go to Windows’ Device Manager, look for the Clip drive/the drive that shows an issue, right click on it, and unauthorize. This is done with the Clip not connected to the computer. (Sorry for the general directions–I haven’t had to do this for quite some time.)
