just purchased clip+; uploaded and am listening to audiobook just fine. after turning clip+ off … then later on; of course the clip+ goes to the audiobook…but after I pause the audiobook, press menu, I scroll to FM radio the menu freezes…and by freezes I mean no buttons pushed by themselves or in combination gets the menu to change. So the menu light and FM radio menu option stays lit until the battery wears out. last time this happened (yesterday) I plugged the clip+ into the computer (while computer was on of course) hoping that that would trigger unfreezing, but alas that didn’t work…actually, the clip went unacknowledged by my computer…I then went to work (with the computer now off) and when I came back turned on the computer attached the clip+ & the clip started charging & working just fine…until this am when the above happened.
plz help to stop clip from freezing
also, can I use my cellphone charger (input 100-240v~50/60hz 0.15a; output 5.0v =550ma) to charge the clip+…it takes for ever to charge via usb & I think this option would be faster
thank you
