I have a Clip 4GB revision 1, firmware 01.01.30. Upon attempting to upgrade to 01.01.32 using the Firmware Updater, I got an error message saying that the upgrade failed. I then tried to upgrade manually, but I got a message saying that wasn’t possible.
After that, the Clip has been impossible to start, and instead freezes at the welcome screen. Connecting to a computer reveals that all the data in the internal memory has disappeared, instead showing weird “empty” files. Upon disconnecting, the Clip freezes at the “disconnected” screen.
Resetting the drive is of course useless, updating the firmware cannot be done, and formatting the internal memory is of no avail. It is for these reasons that I have registered to these forums, searching for a solution to my problem. Any help would be most appreciated.
Message Edited by isaho on 07-03-2009 04:39 AM
