I just got my Fuze, it works great for music and my mp3 audiobooks.
The only con so far is a “chirp” noise between tracks. It happens when one track ends and the next starts. Is there any way to stop it?
Amber
Amber
Mines works fine.
I just listened to the same file in WMP on the computer, there was no noise between tracks; so the noise is not on the tracke but produced by the Fuze.
Maybe your earphones? XD
Is it happening when you skip tracks or let them play all the way thru or both?
From what i know is, it happen when the track ended.
I’d say your listening to your music a little too loudly. I once had it way up there once (I don’t remember why) and I think I heard a beep… maybe not, though.
-The Saxmaster
Message Edited by saxmaster765 on 02-20-2009 06:01 PM
AmberJean…I am here to back you up and actually joined this forum because of you. Though I love my new Sansa and I came here for video downloading issues…I get the ‘chirps’ between tracks a lot! It’s not everytime, but it is often. The thing is that the chirps can be so loud that it causes me to jump! And, no, I don’t have the volume up full blast at all! I have heard all these same files on my ‘old’ Sansa and NEVER had this issue. I’d love nothing more than to read a resolve…or at least a cause for this!
The chirp you are hearing may be caused by the data packet that is embedded into the mp3 file.
The ID3 tag embedded in every mp3 and WMA file includes the album art, and metadata information, the album name, genre, artist, etc.
Note that this situation does not appear very often, which is a promising sign.
The burning questions are: where are your audio files from, what was used to rip the mp3 or WMA file, and what format are the ID3 tags. Somewhere in this combination lies the answer.
As a side note, does the album art display for these tracks?
Let us know the particulars about your music files, and we can pinpoint the issue in your case.
Normally, the Sansa will mute during the reading of the song data, but it’s possible that something is wrong in the header of your files.
Bob :smileyvery-happy:
Ok…time to fess up! The files I listen to are coming from downloads from AM radio stations…OR from a disk that I won on Ebay. Still thinking that they should be playing normally anyway
Uh, no.
Please try to respect others’ concerns by keeping posts on-topic. Humor is fine, but trying to find a solution through numerous interjections can be quite irritating.
For this case, specifics about the original poster’s files are needed.
Not all audio files are the same. There is information in the file that can cause issues, depending upon the encoder and format used.
µsansa
This is possible BUT there is no noise between tracks when the same files are played on my computer with Windows Media Player. I also checked the tracks with an editor, there is no noise at the beginning or ending of the tracks. The noise is only on the Fuze.
Amber
Amber,
WiMP handles the files differently than a portable device. On the computer, the “virtual” player behaves differently than a DAP, as it’s running on a processor capable of many tasks, at a much faster clock rate.
In short, just because the song plays on the computer, this doesn’t assure that it will play “in the wild”.
At the clock rate that the Sansa is operating, the metadata passes by in milliseconds. If there’s a bit set incorrectly, for example, the result can be a chirp, a brief pause, or a simple click.
Bob ![]()
Message Edited by neutron_bob on 02-20-2009 09:02 PM
As others have pointed out, it could be due to the metadata embedded with the MP3. Sometimes, tags other than ID3 are attached to MP3 files. I’ve heard of APE tags and Quicktime tags causing problems like this. When a player doesn’t know how to interpret them (in this case, the Fuze), it usually treats it as audio data, resulting in a momentary glitch or pop, typically near the beginning or end of the song (depending on where the tags are stored in the file.)
Players that recognize this data as tags (WMP) will just pass over this data.
I’d try removing any unneeded tags / metadata from the affected files. I’ve never had to use it myself, but I’ve heard MP3tag does a good job with this.
Mp3tag - the universal Tag Editor (ID3v2, MP4, OGG, FLAC, ...)
How would I remove unneeded tags or even find out what tags were attached to the files?
I get this ‘chirp’ sometimes, too. I don’t recall it ever happening on my E280, or my Clip, but it happens fairly often on my Fuze. Hadn’t occurred to me that it might be reading tag data as audio.
I only use MP3’s and only have ID3v2 tags on them (I erase everything else, including album art.)
I also have the latest firmware, but I did notice it happening before my last update, too
Message Edited by Odd_Bob on 02-21-2009 03:06 AM
MP3Tag.
One of the most incredibly useful programs I’ve ever discovered (for MP3’s, anway.) And it’s free!
Download MP3Tag, and set it to write your ID3 tags as ID3v2.3 ISO 8859-1.
I got MP3Tag, it looks like a very useful program There were V2 and V1 tags on the files. I removed the V1 tags.
Can I remove the tags on the files on the Fuze when it is connected, or do I have to upload the files again?
Dont remove the tags. They are what tell you player Song Title Album name and Artist, so if you need that stuff you have to have tags, what you need to do is to leave only this info on the tag. So Make sure the Title Artist and Album are set correctly, then save them to your computer. I would suggest removing the files that have this issue from the player and then adding the ones whose tags you fixed back to the player. Some have suggested that you can tag the files on the player but I dont want to try it.
