Can I use the Samsung SAC-48 (from my DigiCam) to charge my Sansa Clip+ and listen to the music while it is charged.
The technical data are:
Input: 100-240V ~ 50-60HZ 0.2A
Output: 4.4V 400mA
Is it sufficient enough?
Thanks and regards.
xanilux
Output: 4.4V 400mA
Thanks and regards.
xanilux
Thanks for your answer.
What happens when the voltage is too low?
Is there any risk (charger or/and player can be damaged) if I try it?
Regards
@xanilux wrote:
Thanks for helping me!
I am from Germany so I will buy something like this:
That looks wunderbar. ![]()
