Charging my new clip
When charging my new 1GB Sansa Clip does the battery stop blinking when it is fully charged. Newbie here please be patient with me. Thanks
Chuck:neutral_face:
Yep–and the battery icon is shown as full.
Yep (if I recall correctly)–and the battery icon is shown as full.  You’ll know.   :wink:
P.S.  Welcome!
Message Edited by Miikerman on 03-17-2008 10:55 PM
Yes it will stop flashing when fully charged, can take a few hours the first time. With lithium ion batteries it’s a good idea to let it drain down to almost to a complete discharge but not dead, and without charging between uses about twice to condition the battery .After that it should hold a good long charge. Don’t Worry if you didn’t do this the first few times just should be done early in the life cycle of the batt. No lithium ion batts don’t develope a memory, this is done to fully activate the nature of the chemical properties and the reaction that takes place. Some techies may argue this but why then just about every batt of this type and others never hold the full rated charge at first?
hope this helps
TROY
Interesting.  Batteryuniversity.com, a pretty good source, doesn’t mention that new battery conditioning method, as best I recall  Where does the concept come from?
What it does recommend is to generally recharge at 30-40% of capacity and to fully discharge every now and again to reset the battery gauge.
Thanks for your help everyone. My Clip is all charged up and I have to say for the money the Clip is one heck of a great MP3 player.
Chuck:smiley:
You will also notice that, after a few charge / use cycles, the battery service life will increase a bit.  I noticed that the battery drained more rapidly on my four Clips for the first two cycles each.
Amazing service life, considering how small it is!
Bob  :smiley:
Thanks for the info Bob. Yes it is an amazing little gadget. If they would give it a micro SD card slot it would be perfect.
Chuck:smiley:
They saved that for the new Fuze.  I agree with you, though–it would be a killer on the Clip.
That is not what Batteryuniversity.com recomends. What they are refering to is what is knowen as digital memory, and to reset the battery gauge they recomend to do a deliberate full discharge and recharge every 30 charges or so to correct this problem. Do you have any helpfull information to give? Know anything about Chemistry? or just have too much time on your hands. That method I mentioned comes from China BAK Battery Inc. buy the way one of the worlds largest lithium Ion battery manufacturers. Ever try it? did you graduate from battery university.com? or what? Here is a clue Use your time to help people not **bleep** off, contradict what other people say and give out false info. mike the sansa Regressor.
X-Blades
Actually, what I simply noted above and what you simply repeat comes from batteryuniversity.com and others’ take from it, for resetting the battery gauge (as you repeat) and to extend the life of a battery.  I’m not quite sure why you’re ranting about that or the simple question for the source for your battery conditioning recommendation.  Thanks for noting China BAK Battery Inc., although it actually would be more helpful for a link to the information you report–the China BAK Battery Inc. website that I found (http://www.chinabakbattery.com/default.asp) doesn’t seem to have battery tips or reommendations (maybe I just missed it or there’s an alternate location, which you didn’t provide).  Perhaps you could be helpful and provide it.
Actually, what I simply noted above and what you simply repeat comes from batteryuniversity.com and others’ take from it, for resetting the battery gauge (as you repeat) and to extend the life of a battery.  I’m not quite sure why you’re ranting about that or the simple question for the source for your separate battery conditioning recommendation.
Thanks for noting China BAK Battery Inc., although it actually would be more helpful for a link to the information you report–the China BAK Battery Inc. website that I found (http://www.chinabakbattery.com/default.asp) doesn’t seem to have battery tips or recommendations (maybe I just missed it or there’s an alternate location, which you didn’t provide).  Perhaps you could be helpful and provide it.
Actually, what I simply noted above and what you simply repeat comes from batteryuniversity.com and people’s take from it, for resetting the battery gauge (as you repeat) and to extend the life of a battery.  I’m not quite sure why you’re ranting about that or the simple question for the source for your separate battery conditioning recommendation.
I just bought the Sansa clip and am charging it for the first time.  The battery is not flashing anymore but it still shows connected.  Will there be anything that runs across the screen saying battery charged?
Also should I charge in between uses or drain all the way?
Thanks.
If the battery icon shows full, you’re done ( roughly–it’s not a precise “tool” ).  No separate message.
Batteryuniverity.com provides seemingly nice info. on how to treat modern batteries.  Generally, it’s recommended not to get to empty–only do that now and again to re-calibrate the battery gauge.  I think that people tend to think that recharging at around 30-40% works well and is best.  Partial charges do not harm the battery.
Message Edited by Miikerman on 04-24-2008 10:53 AM
