I connected my player directly to the AC supply with AC to USB adapter.
After that i shut down my clip.
After 1 hour when i turned it on i didn’t see any progress.
Should the clip been charged when it is shut down but connected ?
If you shut it off it won’t charge. Just pause it, and it will charge just fine.
Thank you.
That was my thought, just wanted to be sure.
The processor of the Clip manages the battery. The device has to be “on” to charge.
Bob :smileyvery-happy:
