jeanneb
1
Can I connect the c200 to a computer in Italy to charge
the battery? I will not be using a voltage converter. Don’t
know whether Euro computers run on 220—or do they convert
to 110 (thus making it OK to connect the mp3)?
Lastly, does anyone know if the cable ports are the same on
Euro computers?
Thanks (Grazie)!
enigma
2
they should eb the same, if its a usb port;it will charge just fine. The power supply on the computer should act as a converter.
drlucky
3
all computers run on DC power anyway so the conversion is done by the power supply. it will work fine no wories.
