Windows Media Player will not play songs anymore but just runs through them saying Media Changing since using Sansa View. Have deleted Sansa Media Converter and removed Sync but still happens.
Help.
Help.
What format are the files you’re trying to play? Are they DRM-crippled? You might also try updating or re-installing WMP.
Most of the files were WMA and some were MP3 but it seems all have been converted to AUDIO files on the main computer that loaded Media Converter. My laptop that had the Sansa software loaded but not the Media Converter is fine, Just seems a bit stange having done a Restore on the main computer and it is still there thought that Sansa Media Converter may have a Virus showing on Vista 64bit.
Cheers for your reply.
