I have two microsdhc cards ( for different types of audiobook material) and might buy more.
I am thinking about getting something to protect my fuze especially when I am travelling.
So, how easy is it to take the case off and put it back on every time you change the card? Would a flexible skin or a hard case be better, and do they get damaged by being constantly put on and taken off?
I hope someone has tried this and can give advice.
cheers.
cheers.
The silicone skin that I have has an opening for the card slot, if that helps. :smiley:
Thank you Marvin, that sounds like it is what I need.
So does my (hard shell) Crystal Case. Oh, dillema! hehehe
Any case designed FOR the Fuze will have an opening for the card slot.
That’s not fair. Mine didn’t. I had to cut one for it. Wasn’t impossible or extra hard, just not that easy (used an exacto knife). Since I use my card always and change them a lot, I need one. If I didn’t, I wouldn’t have cared.
So when looking for one, maybe see if it has one, if buying online, ask the buyer if it’s not mentioned.
