Can't seem to uninstall WD Discovery
So today I was not granted perms to install some stuff on my own disk. So I started out with uninstalling my other WD stuff because to me, it’s too much of a hassle. I thought that would be the end of my problems. It wasn’t. So I tried uninstalling WD Discoverer, but the apps section is blank (see attached photo). So I did some digging and found out there was another way to uninstall it, I went to the folder marked “More WD Apps” I opened the “Uninstaller” Folder and then, nothing. Any help would be greatly appreciated, I’m a bit of an ■■■■■. (I’m on mac if you couldn’t tell).
Hi DasPotato,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
