i have an old WD elements 1tb that is ou tof warrenty the thing is that it has come up in disck managment as unalocated and i cant initilize the disc because it says it has been write protected. I have done so many things to get it to work. hellp me pls
You could try the Minitool partion,this may solve your problem,you can get it at http://www.partionwizard.com/free-partion-manager
nope i tried that driving me crazy
i’ve never encounted this type of error … but doing a gOOgle search, have you tried these ?
http://smallbusiness.chron.com/disable-write-protection-hard-drive-54089.html
so once the “read only/write protection” is disabled, hopefully you’ll be able to format the drive ? (i hope)
