I am a more or less happy user of 3 WD HDDs. I installed and ran the LGD test, which keeps showing that it can not complete test for the 1.5 Tb drive. Well, I have to get it repaired or changed. However, it also shows that the other two drives passed the Smart Scan test, but when clicking on the test result multiple errors appear on both the 2 Tb and the 3 Tb drives, and the green checkmark of “pass” turns red (fail). Now I do not understand: all my brand new drives are failing? chkdsk /f /r /x found problems only for the 1.5 Tb HDD so it is the only faulty. I do not understand why the other two drives show the following problems.
I registered at WD webpage and tried to contact customer service but I simply can not find the Model Number for my drives. Properties (LifeGuard Diagnostics) tell the serial number and that these are all WD Ext HDD Model 1021, but nothing else! I can’t find this by search at WD’s support page and thus I can’t even post my issue there.
So, the errors of these disks:
Detailed errors for all the drives:
Power-off retract count ID E4 Warranty 1
Unknown ID 64 Warranty 1
Multi Zone Error Rate ID C8 Warranty 1
UntraDMA CRC Error Rate WID C7 Warranty 1
Raw Read Error Rate ID 1 Worst 1 Warranty 1
Drive 1.5 Tb (first test):
Test Option: QUICK TEST
Model Number: WD Ext HDD 1021
Unit Serial Number: [Deleted]
Firmware Number: 2021
Capacity: 1500.30 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 2 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 2!
Test Time: 10:05:16, March 30, 2014
Drive 1.5 Tb (2nd test):
SMART Status: PASS
Test Result: FAIL
Test Time: 10:05:57, March 30, 2014
Drive 1.5 Tb (3rd test):
SMART Status: PASS
Test Result: FAIL
Test Time: 10:07:03, March 30, 2014
Drive 2.0 Tb (first test):
Capacity: 2000.40 GB
SMART Status: PASS
Test Result: PASS
Test Time: 10:12:37, March 30, 2014
Repeating the test on the same drive now gives fail:
SMART Status: FAIL
Test Result: PASS
Test Time: 10:37:57, March 30, 2014
Drive 3.0 Tb (first test):
Capacity: 3000.59 GB
SMART Status: PASS
Test Result: PASS
Test Time: 10:57:36, March 30, 2014
