I accidentally bought a WD 4TB My Passport Drive that’s apparently not compatible with my MacBook Pro, High Sierra 10.13.6. I’ve seen the instructions for reformatting the drive and I’ve attempted to reformat it. All to no avail so far. In particular, I get stuck at the part that says click the “eject” button in Disk Utility. Nothing happens when I click it. I’ve tried skipping that step and going straight to “erase” but it fails to mount.
Just eject your drive safely plug it back and then follow the instructions again using the link:
However, if you are not able to format the drive using the above mentioned article then I would recommend you to follow another link which is provided below:
