Hi, everyone.
I have bought WD Elements 500GB (compatible with USB3.0 and 2.0) on last 2 weeks.
Everything is fine when the first time i used it.
After that, i can’t access the harddisk, eventhough the windows “Notification Area Icon” showed that i already connected the harddisk correctly.
I also checked on Device Menager to see if my harddisk have any problem, but it shows that “The Device is working properly”.
I tried to update driver via online, but it shows that my driver is already up to date.
After that, i tried to disable and unistall the device, but the problem still occured.
Any suggestions or comments are appreciated.
Thank you.
